Latest: tbafonso
Overall: 17130
Online Now [311]:
Visitors: 310
Today: 41891
Total: 103627693
Forums › The Car › 206 Problems › Speedometer bulbs
Speedometer bulbs
zniko1990
PostPosted: Thu Jan 22, 2015 12:13 pm Up
Hi. I would like to change a speedometer bulbs. Any help please?
zniko1990
mtempsch
PostPosted: Thu Jan 22, 2015 2:00 pm Up
From memory (not experience since I'm multiplexed and cluster is lit by LED's that are soldered to the board):
Pop off the top cover (pull it towards you).
Unscrew the torx screw holding the cluster.
Move and tilt cluster towards you.
Undo connectors for better access/enable full removal.
Untwist bulb to change.
Put in new bulb.
Reassemble.
This HowTo for changing the LED's on a multiplexed cluster offers some illustrations that might be helpful.
Note that pre-plexed clusters have 2 connectors.
On this pic you can see the rear of the unit with connectors and bulbs
Silvermetallic 2004 206 RC
zniko1990
PostPosted: Fri Jan 23, 2015 11:53 am Up
Thanks for your help Smile
zniko1990
