Latest: airmastertapes
Overall: 17133
Online Now [362]:
Visitors: 361
Today: 110333
Total: 106822146
Forums › The Car › 206 Problems › 206 Gt will not start.
Go to page 1, 2, 3, 4, 5, 6  Next
206gt160
PostPosted: Sun Dec 07, 2014 11:23 am Up
Right so I have only just got the car on the road for the first time in possibly 2 years and she decided to cut out on me, now it will not start up but it does turn over. I'm thinking it is fuel related. I can here a very low noise at the fuel pump when the seat is up when I turn on the ignition but I seem to remember it being louder.
Couple of questions for you guys.
1. How loud is the fuel pump when you guys turn on the ignition.
2. which wires do I need will I need to probe into with a volt metre to find out if power is getting to the pump. Electric's and me are not one with each other. Might do a night course.
3. Where are the fuel pump relays situated. (Pics would be great if you can)
4. Where are the fuel pump fuses. (Pics would be great if you can)
5. Please could someone please take a photo of there full fuse box inside the car, as I do not know where the cover showing me what and where the fuses go has disappeared to.
6. If the fuel pump is getting power to it could it still be fuel pump related
any help would be greatly appreciated.
macj
PostPosted: Sun Dec 07, 2014 11:57 am Up
you may be better off checking your fuel flow at the injector rail if you are not good with wiring. Take off the pipe from the fuel pump, pop it into a fairly deep container, cover it with a cloth to stop splashing and turn on the ignition briefly to check flow.
206gt160
PostPosted: Sun Dec 07, 2014 12:25 pm Up
A simple voltage test I am ok with its when you have big looms I haven't had to this before tbh. That's a good idea I will give it a go tomorrow when I go to the car. If the fuel does flow through the system do you have any idea of what else could be causing the not starting.
1999 206 Gt... Gti180 inlet, Gti180 exhaust manifold, Gti180 injectors, Gti-6 throttle body, Custom Adapter pipe to mate the throttle body to intake, Gti180 alternator, Gti-6 ICV, Straight through stainless exhaust system, cat cams (apparently), Avo coilovers, short shift gear stick, stripped out with fixed back bucket seat and harness, flocked dash, momo steering wheel and D2 solid boss, real carbon cold air intake, Gti-6 front calipers and 288mm disks, rear drilled and grooved disks, morette headlights, sp bonnet grill 71,456 miles
2008 Audi A3 2.0 Tdi 170
206gt160
PostPosted: Sun Dec 07, 2014 1:40 pm Up
Ive been reading that its a possibility it could be the mulitfunction relay under the bonnet. I will test the pump in the morning and see where I end up.
206gt160
PostPosted: Mon Dec 08, 2014 5:12 am Up
Checked the pump at the valve about the fuel rail and everytime that I turn on the ignition and press the valve in fuel comes out, so it does seem to be getting fuel to the injectors.
Any other ideas? I dont have use of pp2000 to get the diagnostics checked so its a trial and error game
Razor34
PostPosted: Mon Dec 08, 2014 7:11 am Up
Take it to a dealer mate and get it plugged in to check
Ray
206gt160
PostPosted: Mon Dec 08, 2014 7:19 am Up
Well I have currently got the battery disconnected so I will go back tomorrow and see if it starts up after an ecu reset. I have spoken to a local garage with a diagnostics machine that they will come round with tomorrow if I am still struggling. It is so annoying that it is not obd2 and I can not use any of my readers on it. I can not get the car to a dealer as it is not starting.
206gt160
PostPosted: Mon Dec 08, 2014 12:01 pm Up
I fitted a new fuel pump today and cant hear it prime and there is no fuel coming from the valve at the front, so i put my old one in and thats doing the same. No priming sound and also no fuel from the valve. Ive took the multifunction relay out to clean up.. does this relay have an effect on the pump. Im going to get diagnostics on it possibly tomorrow. I also need a new pump retainer (the black ring that holds the pump in) due to it getting damaged due to it being 15 years old. The pump is not air tight would this stop it from priming
PostPosted: Mon Dec 08, 2014 12:16 pm Up
Have you considered an immobiliser fault?
206gt160
PostPosted: Mon Dec 08, 2014 12:30 pm Up
When I put the key in the ignition with the door open it makes no bleeping.. if this helps
206gt160
PostPosted: Mon Dec 08, 2014 12:32 pm Up
How would I sort the immobiliser fault out and also whats the reason for the car driving then cutting out because of the immobiliser? I dont have a clue about the electrics side.
PostPosted: Mon Dec 08, 2014 12:43 pm Up
maybe you have a clogged fuel filter mate,replace it,or check if the fuel is coming out from the feed pipe in the engine bay,I wonder why you replaced your fuel pump while yours was working,if fuel is good,then it maybe immbo. but to quit guessing,the diagnostic tool is your best choice.
206gt160
PostPosted: Mon Dec 08, 2014 12:51 pm Up
I thought I remembered the fuel pump being louder when priming so I decided to change the pump. Definitely fuel related due to no priming noise, I will get the diagnostics on it. Also I will try the immobiliser reset.
206gt160
PostPosted: Mon Dec 08, 2014 12:52 pm Up
Still don't get why it would prime and then stop priming.
gazza82
PostPosted: Mon Dec 08, 2014 1:15 pm Up
You haven't lost the chip out of the key have you? Or it's been so long the BSI and key have become disconnected ...
Does the central locking from the key button work?
Page 1 of 6
