Latest: Puggingalong
Overall: 17129
Online Now [131]:
Visitors: 130
Today: 27159
Total: 101384202
Forums › The Car › 206 Talk › 206 180 .. nimrods
206 180 .. nimrods
lisa206
PostPosted: Sat Feb 07, 2015 7:23 pm Up
just a quick question,
anyone got any pics of a 180 with nimrods on ?
I want to see if it would sit too high on them , at the moment I have a 180 with silver 180 wheels , but I have a set of black nimrods that I was going to put on until I refurb my 180 wheels.
LISA 206 180
PostPosted: Sun Feb 08, 2015 3:12 am Up
I'd bet it would look like a 138 GTi....maybe a few mm lower but not much. I bet it would handle and ride better too.
206gt160
PostPosted: Sun Feb 08, 2015 4:45 am Up
Well if the tyres are the same thickness i.e 40/16/195 and 40/17/215 (just for example) then the car would be half an inch lower to the ground but there would be an extra half of an inch gap between the arch and the top of tyre. Handling in my opinion would be better just like Edward mentioned.
PostPosted: Sun Feb 08, 2015 8:15 am Up
They actually look worse on a 180 than on a 140 unless you lower it alot
PostPosted: Sun Feb 08, 2015 10:48 am Up
60mm? It doesn't need dropping that much.
