Forums › The Car › 206 Talk › track rod end picture |
Posted: Wed Apr 29, 2015 3:48 pm |
As above does anyone have a picture of how their track rod ends sit, replaced them separately as I took them off but have the feeling the old ones were fitted the wrong way round sure my hdi were the other way just want to be sure before I drive the thing
Posted: Wed Apr 29, 2015 4:06 pm |
They sit on top of the hub.
