Online Now [500]:
Visitors: 499
Today: 102939
Total: 106297069
Forums › The Car › 206 Problems › 206 1.4 HDi not idleing
Go to page Previous  1, 2
David_P
PostPosted: Thu May 07, 2015 1:02 pm Up
Check the fuel lines for holes, the ones under the air filter.
Pump the primer bulb, if you see bubbles, that's air in the lines.
kehlyr359
PostPosted: Thu May 07, 2015 4:23 pm Up
Thanks for the reply, but i think I said in the original post that all fuel mlines had been replaced already
David_P
PostPosted: Fri May 08, 2015 1:25 pm Up
Yes, you did !
Absolutely no tiny bubbles in the clear fuel line ?
kehlyr359
PostPosted: Fri May 08, 2015 4:28 pm Up
David_P wrote:
Yes, you did !
Not that can be seen, and i have a `1.4 hdi and that sometimes has small bubbles in and doesn't affect the running of it at all.
It almost as if the fuel is being instantly shut off, it doesn't misfire it just dies.
the fault is something to do with the pump constantly priming, it shouldn't. When running the fuel pressure is absolutely fine. It seems most likely now that the problem is ecu based
PostPosted: Sat May 09, 2015 6:51 am Up
Once the tank pump in the rest is primed it will stop, but when the engine is started it will keep running. There should be no air in the fuel lines at all. On the 1.4 it's usually the lines that run around the battery that rub letting air in. Tbh it sounds like air in the system somewhere.
Page 2 of 2
