Forums › The Car › 206 Talk › Lowering 180 |
Posted: Wed Apr 01, 2015 5:38 pm |
Hi all,
Want to lower my 180, anyone know if a 50mm drop all round would be too much ???
Anyone lowered there's to 50mm??
Posted: Wed Apr 01, 2015 8:21 pm |
Mines 50mm drop all round ..
Perfect for me . Does catch now and again on major speed bumps ..
| If it aint broke dont fix it ! | |
Posted: Thu Apr 02, 2015 2:15 am |
50mm is a little excessive, 30mm usually looks good and still rides OK without scraping, don't forget your wheel arch trim fills some of the gap out so you don't need to go as low as you think.
Posted: Thu Apr 02, 2015 2:53 am |
30 mm is the perfect drop. Looks purposeful and remains driveable too.
Posted: Thu Apr 02, 2015 3:00 pm |
It also rubs the arch liners on full lock .
25/30 mm probably best. These boi's do speak from experience..
I just like sitting on the floor..
The sump is the target area(lowest point) so be wise.
