Latest: Beduff1977
Overall: 17134
Online Now [245]:
Visitors: 244
Today: 43103
Total: 107223966
Forums › The Car › 206 Problems › 206 gti 180 start/ running problem
play2win96
PostPosted: Sat Apr 11, 2015 1:17 pm Up
hi,
I have a 2004 206 gti 180, this morning I went to take it out and it kept cutting out if I wasn't revving it. it continued to get worse, the management light came on, exhaust sounded like it was misfiring and it would only start if I was revving it whilst turning the key... wondered if anyone could help me out? thanks in advance! Razz
Project2062014
PostPosted: Sat Apr 11, 2015 1:26 pm Up
Not sure .. Sound like fuel being blocked. Clean out the injectors?
PostPosted: Sat Apr 11, 2015 5:37 pm Up
Cool pack probably. Get the codes read.
cainw1
PostPosted: Sun Apr 12, 2015 2:13 am Up
I recently had some starting problems (starter motor packed up) but when changing it also found out that the cold start wire had been damaged and come loose.
PostPosted: Tue Apr 14, 2015 3:48 pm Up
As Steve206.
Read the codes and note them.
Clear the codes.
Start and, if you can, drive the car a short distance.
Reread the codes and work with the new codes.
