Latest: tbafonso
Overall: 17130
Online Now [148]:
Visitors: 147
Today: 4800
Total: 104514472
Forums › The Car › 206 Talk › Emergency puncture repair Peugeot 206 GTI 180
keywest
PostPosted: Thu Apr 16, 2015 11:01 am Up
Hi all,
When the 206 GTI was released what repair pack was in the boot, was it 2 x 300ml in the boot.
As i picked a box and weld up from eBay from a cc and just seeing if it can use it on the 180.
Thanks James
yokel
PostPosted: Fri May 01, 2015 3:33 am Up
Yes, two bottles of 300ml is correct.
Don't know if there's anything special about the 180 kit...appears to be all in French.
PostPosted: Fri May 01, 2015 6:00 am Up
Be warned that using this stuff renders a potentially repairable tyre scrap!
It also has maximum speed & distance limitation's you need to be aware of once used inside a tyre.
Its also useless if you suffer a blow out.
PostPosted: Fri May 01, 2015 6:37 am Up
If you take a tyre that has had that in it into a tyre place for replacement, make sure you tell them. I know of a few places that refuse to touch them as it goes everywhere when they take the tyre off the rim
omega
PostPosted: Fri May 01, 2015 3:16 pm Up
I sell puncture safe works well is speed rated and washes out if need be, wont stop a blowout or side wall damage
1245678
