Online Now [121]:
Visitors: 120
Today: 48984
Total: 138727946
Forums › The Car › 206 Talk › Electrical Connector
Shadowstalke
PostPosted: Mon Mar 23, 2015 7:40 am Up
Hi All
Any idea what these are called, and whether I could buy any (and where from)? There are from the H7 Ph.2 headlights, and are the connector between the car loom and the H7 bulbs for Main/Dipped beams.
Second question. I have some new lights (Halo's) that I have done the wiring for the halo rings for and will splice onto the sidelight loops with scotch blocks, but the connectors for the projector and full beam lights are H1's, which terminate in a H4 connector. Could I run the 2 neutrals on the h4 to the black neutral on this connector, and the the live from each h4 to the respective lives on this connector? As there is already a relay in place behind the dash?
1.6HDi. Pull like a train. Smokes like one too!
No Smoke, No Poke!
oldskoolz
PostPosted: Mon Mar 23, 2015 11:44 am Up
Peugeot do not sell these separate, your only bet would be getting them from a scrapped car
Black 206 Gti. Soon to be 2.2
Shadowstalke
PostPosted: Fri May 08, 2015 8:11 am Up
That's alright, was replacing lights with Ultra Halo ones anyway so cannibalised the old OEM's!
No Smoke, No Poke!
PostPosted: Fri May 08, 2015 10:21 am Up
I bought new terminals from the Peugeot dealer for a crank sensor connector so I think you can get anything from them if you know what the part number is.
