Latest: tbafonso
Overall: 17130
Online Now [85]:
Visitors: 84
Today: 19322
Total: 103810862
Forums › The Car › 206 Problems › 206 1.4hdi drive belt tensioner pulley adjustment
fofs_phil
PostPosted: Thu May 14, 2015 7:09 am Up
Hi Everyone,
New to the forum !
My trusty 206 1.4HDI needs a new drive belt (old one broke)
I have got a new one, almost fitted it but can not see how to adjust the tensioner pulley to finally fit the belt.
I can release the centre bolt on the tensioner pulley but there appears to be another mechanism behind it for adjusting it.
1. Do i need any special tools for this ?
2. Any pictures plus a description of how to release and then re-tension the adjustment pulley would be very much appreciated.
Thank you in anticipation.
Phil
southwestchap
PostPosted: Thu May 14, 2015 9:22 am Up
15mm spanner on the tensioner pulley nut and lever the tension off.
fofs_phil
PostPosted: Thu May 14, 2015 9:33 am Up
Thank you i will give it a go.
fofs_phil
PostPosted: Thu May 14, 2015 11:01 am Up
Fixed - Used the 15mm socket from below - My son fitted the belt from above.
southwestchap
PostPosted: Thu May 14, 2015 11:06 am Up
Glad to hear. They're a fairly simple setup and as you've said, easier with two.
