Latest: tbafonso
Overall: 17130
Online Now [57]:
Visitors: 56
Today: 39007
Total: 104509063
Forums › The Car › 206 Problems › Shock noise problem?
MrMac
PostPosted: Sun May 10, 2015 3:05 pm Up
I have a strange one for ya. I had the front shocks changed just before Christmas..the old ones were leaking and creaking! Anyway, all was fine. Now that it is summer driving along with the windows open every time I go over a bump on the left hand side, at the front, it makes a noise. The only way I can describe it is if you imagine a nut and bolt with a washer....the nut isn't screwed down all the way and the washer would be bouncing about making a noise. I have taken it back to the garage and nothing was loose. They checked the discs, pads...the spring, had it up on the ramp and found nothing wrong at all. When I had the cat changed at a different garage they couldn't find anything loose when up in the air. It is rather annoying...anyone had anything like this?
PostPosted: Sun May 10, 2015 3:18 pm Up
Drop links?
MrMac
PostPosted: Sun May 10, 2015 3:45 pm Up
I don't think so....one needs replacing but that noise is like a dull bump...I am used to them going...replaced them myself in the past plus the noise from them going has been consistent on all cars I have owned...
By the way, one garage said they would change the drop links but they must do the tracking....£100!
Project2062014
PostPosted: Sun May 10, 2015 7:24 pm Up
Top mounts tight ? ( X 3 bolts)
The damper bolt at the top tight?
You sure it's the front ? Bumper ? .
DeadEyePaul
PostPosted: Mon May 11, 2015 3:47 am Up
I too think its the top mounts
MrMac
PostPosted: Mon May 11, 2015 1:55 pm Up
They checked the bolts, all tight. I think I'll take it to another branch to let them take a look at it...if they find anything I'll spring it upon them that their chums down the road fitted them. Surly they are guaranteed for at least a year?
MrMac
PostPosted: Mon May 11, 2015 2:15 pm Up
Is there anything I can undo/check without removing anything major? I do not have the tools to remove a shock or the know how...but anything that I could check?
Project2062014
PostPosted: Mon May 11, 2015 4:36 pm Up
The lower arm sometimes has a metal protector over the stud . That slots into the hub from underneath .Could that be rattling around ??
MrMac
PostPosted: Wed May 13, 2015 9:24 am Up
I think I have found the problem! Just parked up at work and had a good feel around and, sure enough, I can feel a metal 'cup' thing over something on the lower arm...it is sitting loosely over a nut I think. Didn't have time to fully look but I hope to either tighten or remove it over the weekend.
Project2062014
PostPosted: Wed May 13, 2015 9:44 am Up
2x 17 mm pinch bolt . Good luck getting the lower arm Out.
MrMac
PostPosted: Wed May 13, 2015 12:42 pm Up
Is it something that I can just take off? I am not removing the lower arm.
If the cups are what I think they are they are the metal heat shields to protect the bottom swivel joint from brake disc heat. Have a good look before dismantling as they are probably almost rusted right through and won't go go tight. If you leave them off (some people do) the lower joint will fail prematurely.
Probably only a few quid from Peugeot so get new ones before you strip it.
MrMac
PostPosted: Wed May 13, 2015 12:44 pm Up
Or is it something I can get the garage who fitted the shocks to sort out? Would it be something that they would of dismantled when fitting the Them?
MrMac
PostPosted: Wed May 13, 2015 12:47 pm Up
From what I could feel, it seems to be a thin metal cover that is on top of something not below. It feels circular with a bit 'cut out' that could help it fit flush with something.
Project2062014
PostPosted: Wed May 13, 2015 1:07 pm Up
Remove them there useless & annoying
