Forums › The Car › 206 Talk › Should this move this much?? |
Posted: Sun Jun 07, 2015 2:07 pm |
h all having a juddering issue with my 206 1.4 hdi should the lower engine mount move this much? it looks to me there is a slight split at the bottom of the bush you can just see split rubber in the video. one vid is 1st gear and the other is reverse
Posted: Sun Jun 07, 2015 2:36 pm |
Well...from what I see the bush if very soft,and shows no resistance,it's better that you replace it with a new one.
Posted: Sun Jun 07, 2015 3:15 pm |
That might be normal. It doesn't look broken.
