Latest: Puggingalong
Overall: 17129
Online Now [221]:
Visitors: 220
Today: 15135
Total: 101372192
Forums › The Car › 206 Problems › Starting problems
Starting problems
Stefanrussu
PostPosted: Fri Jul 03, 2015 9:21 pm Up
Hi i have a problem my car wont start it doesnt make any noises or the safe starter clicking nothing and no warning lights on the dash then when i push it and start it on gear it will start and keep on starting normaly for the next week or two and than the same i have tried to change the battrie terminals for better connection and when i took it to the electrion told me that i had dirty on the wires of the stafe starter but after two weeks still the same do somebody have some advise plsss... thx
PostPosted: Sat Jul 04, 2015 3:09 am Up
If an auto electrician has already looked at it then I'll take a guess that he has given the battery a clean bill of health and there is nothing draining the battery overnight. If not, get the battery charged and checked , and replace if necessary.
Do you mean the connectors on the wires? Did you check the earth wire to the gearbox?
A little bit more info about the car might also be useful as there are problems common to different models.
Stefanrussu
PostPosted: Sun Jul 05, 2015 12:08 am Up
Its a 2002 1.4 hdi yes he have given the battrie a check and the terminals are the postive and negative thats connects to the battrie and yes i have checked the eart from the gearbox
darthvalkyr
PostPosted: Thu Sep 03, 2015 1:59 pm Up
I would check the electrolyte level in the battery. When I got my 206 recently it started but was quite lethargic in doing so. One cold morning it really struggled to turn the engine quickly enough and only just got going.
It turned out that the battery needed an extra half a litre of deionised water adding to it in order for the plates to be covered in all of the cells. Since topping up the battery, it is far more energetic, and this has cured the issue. If the fluid level is too low then the battery can only hold a fraction of the charge it should, so will struggle to do anything where demand is high such as starting, which requires the greatest amount of available current that the battery can deliver.
You should look into this as it is a very cheap fix if it resolves the issue. A bottle of water is around 50 - 60p versus £50 for a new battery.
