Online Now [43]:
Visitors: 42
Today: 24651
Total: 116567055
Forums › The Car › 206 Talk › second hand peugeot 206 key
dturbopeck
PostPosted: Mon Jun 03, 2013 1:10 pm Up
if i buy a second hand key fob off ebay, can i program it in with peugeot planet or not? i mean i know you cant program a used bsi unit, but is the key the same? as ive only got 1 key with the car
PostPosted: Mon Jun 03, 2013 1:23 pm Up
It will need a blank immo chip installed and there's a slight risk of it not working and/or getting 'locked-out' of the BSI and making your car a non-starter.
PostPosted: Mon Jun 03, 2013 1:29 pm Up
when you buy a used key,you will need a new immo chip as V9977 said,but if you want to have a key with 2 buttons working,then you need to make sure the the circuit board "Letter" in the end of the Serial number matches the one you have,and ofcourse you need the 4 digit security code so you can program both keys on your car
PostPosted: Mon Jun 03, 2013 1:36 pm Up
Pre plex or multiplex
If you get the right circuit board, yes. I think there are 3 for multiplex and they depend on if front fogs are fitted for some strange reason.
Some BSIs are programmed to accept a certain number of remotes. I think you need to delete all keys and then reprogram the keys that you have.
The new key will be useless to start the car though unless you get a virgin transponder chip and pair that with the car. These chips can only be used once, so if one comes with the used key, it can't be reprogrammed.
iainlovatt
PostPosted: Mon Jun 03, 2013 2:09 pm Up
I hate to burst the bubble. I was unsuccessful I bought a second hand board, same number as the board in my first key, sorted the chip out,, and Boom didnt work!
and the worst thing is, i did everything right which is stated above.
(My Garage)
dturbopeck
PostPosted: Mon Jun 03, 2013 2:19 pm Up
i had this post on the peugeot forum for 2 days and i had no replies, and straight off you have answered my question, thanks guys, i only bought the car to sell on, i will give the new owner this problem.
uttz
PostPosted: Thu Jun 13, 2013 6:07 pm Up
same thing happened to me.. on PP the car is picking up the signal but doesnt recognise it to open or lock the doors.
GTi 180 Obsidian Black
SW 1.6 16v Sahara Yellow
PostPosted: Fri Jun 14, 2013 9:56 am Up
A new multiplexed remote key isn't that expensive from Peugeot, why do people bother with the hassle of 2nd hand keys Rolling Eyes
dturbopeck
PostPosted: Tue Jun 25, 2013 1:26 pm Up
Ok, so I got a blank key with a virgin chip, I also have pp2000, any guides of how to program keys in?
scove1994
PostPosted: Fri Aug 16, 2013 3:06 pm Up
hey
just wondered in anyone knows what key fob i need for a 1.1 206 with front fogs
thanks Sam
PostPosted: Fri Aug 16, 2013 3:57 pm Up
scove1994 wrote:
hey
thanks Sam
I would say either 6554YR or 6554YV
billybodd
PostPosted: Sun Aug 09, 2015 2:16 pm Up
I have a damaged peugeout partner key - does anyone have a used peugeot key I can buy to replacedamaged battery contacts
