Posted: Fri Sep 04, 2015 11:46 am |
Had an attempt at putting my gti calipers on my 2.0 HDI the bolts from the diesel ones are to big. Already checked the closest scrappy they didn't have any. Would i be able to get these from halfords? if i can find out the exact size of the bolts?
Posted: Fri Sep 04, 2015 11:54 am |
Peugeot / Citroen main dealer parts department.
Posted: Fri Sep 04, 2015 12:06 pm |
Tried there close early on a Friday
Posted: Fri Sep 04, 2015 12:20 pm |
They open Saturday morning.
Posted: Fri Sep 04, 2015 12:32 pm |
yeah they're looks like im doing without for another night anyone got any ideas on cost from there?
Posted: Fri Sep 04, 2015 1:57 pm |
If they have them in stock
Posted: Sat Sep 05, 2015 6:48 am |
Peugeot didn't have them in stock, so went back to the breakers they came from and found the exact car they came from. bolts where still in the car but they where actually the exact the same size so why on mine when does the bolts stick out a good 2cm when they're tightened right up? Thread on the bolts are okay and they diesel calipers go on perfectly fine so im confused, Does anyone have any ideas on whats going on?
Posted: Sat Sep 05, 2015 11:43 am |
Hubs are different so must be the problem.
