Latest: Beduff1977
Overall: 17134
Online Now [377]:
Visitors: 376
Today: 7898
Total: 107320337
Forums › The Car › 206 Talk › throttle body size
throttle body size
Steve137
PostPosted: Sun Oct 18, 2015 6:39 am Up
hi everyone i need to know the external size of the throttle body on 206 gti 138, as im looking to remove the plastic pipe that connect to it and replace it with a nice silicone hose instead!!
so if someone could tell me the size of this it would be much appreciated.
PostPosted: Sun Oct 18, 2015 12:57 pm Up
I'd be very careful if changing it because bonnet clearance isn't huge.
Lex206
PostPosted: Tue Oct 20, 2015 8:23 am Up
true,you have to cut off a lot of the silicone hose actually to make it fit.
think you have to look for a 68mm hose
Megane 225 RS
