Posted: Fri Feb 12, 2016 10:41 am |
Hey guys for the last month i have had a loud screech when i turn right only it started when i slightly turned right going 60mph like breaks screeching but im 99.99% its not the breaks(i have tried going 25mph and slamming on the breaks there was a little skid but my breaks are silent), i jacked it up last night the breaks have about 80% left on them so they are good, the disks look good no pitting, the bearings feel good no play,the bushings are solid i gave them a good tug the car moved but the bushes did not.
Then i checked my power steering pump fluid level and its on the "FILL" line so i think i found my problem maybe.
Its a 1.1 2004 peugeot 206
Will one of these be ok?
www.halfords.com/motor...uid-psf-1l
www.halfords.com/motor...luid-500ml
Posted: Fri Feb 12, 2016 11:44 am |
Get the Halfords stuff if you can't get to a motor factors ..
Posted: Fri Feb 12, 2016 4:01 pm |
UPDATE, for anyone who may have a similar problem googleing about.
Went to Halfords she checked on the computer and said it was also compatible.
Got home put a dribble in and the pump is a lot more quiet,not as much whine when full lock like it used to do and did not screech once in driving around for about 30 min as before it would have screeched multiple times so i think my problem is fixed.
Posted: Tue Feb 16, 2016 5:20 am |
Thanks for update!
I think all of them pumps whine on full lock, as they still try to help turning (I know mines do)
