Latest: morgan20
Overall: 17135
Online Now [245]:
Visitors: 244
Today: 155328
Total: 110706940
Forums › The Car › 206 Problems › 206 GTI cooling fan
206 GTI cooling fan
sambelsher
PostPosted: Thu Mar 31, 2016 8:41 am Up
My cooling fan has stopped working i have checked the fan and it working it i put it on to the battery. i have also changed the 2 relays and replaced the thermostat and changed the coolent and bled the system and still no cooling fan any idea what it could be
PostPosted: Thu Mar 31, 2016 9:21 am Up
Could it be a dodgy temp sensor?
PostPosted: Thu Mar 31, 2016 11:44 am Up
If you have Peugeot Planet then:
Global scan will pick up if the fan isnt working as engine ecu knows when it has commanded the fan to run but the fan motor hasnt responded.
OR
Actuator test
Test low speed fan
Test high speed fan
Cooling fan wiring loom is a known 206 weak point for rotting away.
PostPosted: Thu Mar 31, 2016 12:02 pm Up
Does it work with the air con switched on? Alternatively unplug the coolant sensor with the engine running. Fan should come on then.
Chances are the wiring to the base of the relay holder is rotten. It's only wires and terminals so it's not rocket science to fix.
