Forums › The Car › 206 Problems › Brake Discs and Pads advice wanted |
Posted: Sat Apr 23, 2016 3:41 pm |
Hi All,
I noticed the other day the Discs on the front have a nice 4-6mm ridge around the outside... so thought I`d change them when the pads are due soon.
This is on my 1.4 Verve (otherwise bog standard)
Anyway, having a flick around on europarts website today,
they seem to do 4 brands
Eicher £10 each disc
Pagid £20 each disc
Brembo £20 each disc
and Bosch £25.. always the most expensive...
So anyone got any experience of the Eicher ????
They seem so cheap, can they be any good ????
They are vented discs by the way .
thanks for any advice
cheers
Posted: Sun Apr 24, 2016 4:45 am |
Brembo or Ferodo for braking friction components every time.
Posted: Sun Apr 24, 2016 4:51 am |
I always fit Pagid stuff to my cars. They've always been fine.
Posted: Mon Apr 25, 2016 5:05 am |
Eicher are a waste of money ..
