Latest: Puggingalong
Overall: 17129
Online Now [274]:
Visitors: 273
Today: 2675
Total: 101295664
Forums › The Car › 206 Talk › DEW10J4 or EW10J4 (RFR vs. RFN)
neilneil2000
PostPosted: Fri Jun 17, 2016 10:06 am Up
Hi all,
I have a W-reg 206 GTi (pre-plex) with "RFR" in the VIN. Does this mean I have the "DEW10J4" engine variant?
And if so, what's different to the "EW10J4" variant?
2000 (W) 206 GTi pre-plex RFR EW10J4
PostPosted: Fri Jun 17, 2016 1:59 pm Up
A Y reg should have an RFN which means it has two lambda sensors.
neilneil2000
PostPosted: Fri Jun 17, 2016 6:55 pm Up
That's because I put the wrong letter. It's a W-reg!
PostPosted: Fri Jun 17, 2016 8:31 pm Up
As far as I know the only difference between RFN/RFR
ew10 engines is the two lambdas. Although some earlier engines had adjustable vernier pulleys. There might have been other minor differences too.
