Latest: sparrowdclxvi
Overall: 17139
Online Now [97]:
Visitors: 96
Today: 6562
Total: 113046182
Forums › The Car › 206 Problems › Which Oil ? Peugeot 206 GTI 2.0 2003 (136 BHP not 180)
Seanie280672
PostPosted: Sat Aug 20, 2016 3:20 am Up
Hi, Which Oil should I use for a Peugeot 206 GTI 2.0 2003 (136 BHP not 180)
Im getting different answers from everywhere.
Peugeot themselves say 0-30w C3 but can use an alternative of 10-40w semi-synth, thats a big difference in oil thickness.
My mechanic says it 5-40w semi-synth, very difficult to find, can be specially ordered, but costs a small fortune.
Euro car parts say 5-30w full synth.
Any help would be greatly appreciated, plus any recommendations on oil manufacturer, up until now ive mostly used Castrol Magnatec, however, they are very limited as to what they make, 10-40w or 0-30w is all I can get.
PostPosted: Sat Aug 20, 2016 5:45 am Up
Total Quartz 9000 5w40 is what they recommend back in the day.
pAvax
PostPosted: Sat Aug 20, 2016 6:25 pm Up
5w30 or so full synth is what I use I believe.
Current project: Ciri
Silver 206cc - 2.0 - 2001
Seanie280672
PostPosted: Sun Aug 21, 2016 6:26 am Up
Thanks for the reply guys, ive just ordered some Total Quartz 9000 5w40
bloodmeal
PostPosted: Mon Aug 29, 2016 11:02 pm Up
I use 10w40 semi synth
always have..
same gti as you.
gazza82
PostPosted: Tue Aug 30, 2016 3:46 pm Up
5W40 Fully Synth
PostPosted: Tue Aug 30, 2016 4:15 pm Up
Same as a LPG Toyota Tonero counter balance.
