Latest: Worthy967
Overall: 17143
Online Now [528]:
Visitors: 527
Today: 90227
Total: 114387642
Forums › The Car › 206 Problems › Central locking problem
Nottins
PostPosted: Mon Sep 12, 2016 6:58 pm Up
Hi, I was hoping someone could help me with my problem. When I lock my car by the key fob or manually the drivers side and boot locks but the passengers doesnt. If I then open the passenger door it will trigger all the other locks open. I have to physically lock that door on its own. Then if I unlock the car by fob or manually it doesn't unlock the passengers door with the rest I have to do it from the inside. Any advice will be appreciated thanks.
AJAC
PostPosted: Sun Sep 18, 2016 9:26 am Up
Sounds like you need to replace the Passenger door lock assembly. If you can remove it and check if you are getting power
bloodmeal
PostPosted: Sun Sep 18, 2016 4:30 pm Up
this is also happening with mine, but a double press on "lock" seems to lock everything down.
does this perhaps work for you ?
Nottins
PostPosted: Mon Sep 19, 2016 7:36 pm Up
I will check with the double lock thank you. After asking a friend they two said it sounds like I may need a new lock.
Thank you for your replies
