Latest: tbafonso
Overall: 17130
Online Now [46]:
Visitors: 45
Today: 40964
Total: 104348778
Forums › The Car › 206 Problems › Ew10 misfire at 2000rpm
takis_206
PostPosted: Mon Sep 18, 2017 4:42 pm Up
Hello I'm driving a 206 and I have misfire problem at 2100 rpm car shaking misfire a little, have already check coil,spark plugs,timing,injectors, any sugestion ?suggestion ?
peugeot 206
heyziq
PostPosted: Tue Sep 19, 2017 4:03 am Up
try diagnose using pp2000 / diagbox 1st mate
heyziq.com
takis_206
PostPosted: Wed Sep 20, 2017 4:56 am Up
P1336 and p0300 and p0597 but car don't have electric thermostat
peugeot 206
takis_206
PostPosted: Wed Sep 20, 2017 5:14 am Up
peugeot 206
heyziq
PostPosted: Wed Sep 20, 2017 6:27 am Up
can you borrow coilpack from your friend which are okay ,reset the fault, try mate
heyziq.com
takis_206
PostPosted: Wed Sep 20, 2017 3:55 pm Up
Already change nothing happened
peugeot 206
heyziq
PostPosted: Fri Sep 22, 2017 1:32 am Up
try swap throttle body complete?
i had this issue previously change few sensor still having this issue end up change the whole set throttle body from scrapyard
if not then check wiring and ecu as well
heyziq.com
heyziq
PostPosted: Mon Sep 25, 2017 3:48 pm Up
any update?
heyziq.com
takis_206
PostPosted: Mon Sep 25, 2017 4:50 pm Up
Tomorrow I will change camshaft and crankshaft sensor.
peugeot 206
