Online Now [531]:
Visitors: 530
Today: 26740
Total: 105165941
Forums › The Car › 206 Problems › Hub Thread
Hub Thread
ShaunCardiff
PostPosted: Sun Aug 05, 2018 10:46 pm Up
ARGH!
So, lifted the rear up today and noticed a nut missing and then noticed that despite 2 being 17mm, 1 was 19mm. That just annoyed me.
Anyway, grabbed a spare one that I had that should have fitted to find that the nut didn't catch at all when the alloy was on, seems to be missing the initial thread within the hub.
Question time. Do I pick up the Helicoil Thread Repair Kit or can I use an extended length bolt?
Without the alloy, the bolt catches and tightens well so appears to just be the initial few threads.
Annoyed me nonetheless! Evil or Very Mad
ShaunCardiff
PostPosted: Sun Aug 05, 2018 11:14 pm Up
Should also mention, the bolts currently in place are flat seated. I'd normally expect a taper seat for aftermarkets or is this just me?
Just wondering on replacing the whole lot... especially as they're not in the best shape! Of course there is always the option of a conversion kit - has anybody done this on here?
ShaunCardiff
PostPosted: Wed Aug 08, 2018 10:29 am Up
Anybody? Smile
gazza82
PostPosted: Wed Aug 08, 2018 3:23 pm Up
I can only comment on the flat/taper seats and that would depend on the wheel ...
Personally I'd probably fit a replacement hub rather than trying to helicoil it .. also, conversion from/to what? Drum to disc I assume ...
ShaunCardiff
PostPosted: Fri Aug 10, 2018 12:32 pm Up
I was thinking of a hub replacement - I like things shiny anyway!
I've thought about a change from drum to disc but the conversion seems to be a nightmare! Was looking at changing bolts to nuts - there's a few conversion kits available online I noticed, just wasn't sure how suitable they were!
