Posted: Mon Dec 16, 2019 5:01 pm |
I had the blower replaced on local car mechanic, was not faulty, told that there's no power coming to the blower fan.
I think its relay, but can't locate it, and can't find anywhere online where it should be.
Blower doesn't work on any setting on the automatic climate control. I tried locating the blower resistor, but can't find it, all guides show on manual air control only.
Did remove glove box, but can't find resistor
| | ![](images/spacer.gif) |
Posted: Mon Dec 16, 2019 5:16 pm |
Climate control blower motor doesnt have a separate resistor - its built in to the blower motor.
Make sure the correct blower motor is fitted, obviously the climate control version is different to non climate control version.
What year of 206 is it as there's two completely different electrical systems used on the 206.
Posted: Mon Dec 16, 2019 8:41 pm |
MrBSI wrote: |
What year of 206 is it as there's two completely different electrical systems used on the 206. |
Its 2006 year model. Do You know where the relay might be? I tried googling around for its location, but can't find it.
Thanks so much!
Posted: Tue Dec 17, 2019 8:31 am |
In the handbook I have the A/C fuse is no 15, 15amp, in the under dash fusebox, so I would imagine the relay is there too. It doesn't show which are which in the handbook though.
Posted: Tue Dec 17, 2019 10:10 am |
gazza82 wrote: |
In the handbook I have the A/C fuse is no 15, 15amp, in the under dash fusebox, so I would imagine the relay is there too. It doesn't show which are which in the handbook though. |
Thanks, I took a look into both fuse boxes, but if I have any idea how a relay should look like, I couldn't locate a single one. Where else could they be?
![](https://i.imgur.com/fNLo6nJ.jpg)
![](https://i.imgur.com/3qH2d9L.jpg)
![](https://i.imgur.com/b6p10x6.jpg)
![](https://i.imgur.com/Vi3MACi.jpg)
