Latest: flipflap
Overall: 17140
Online Now [62]:
Visitors: 61
Today: 24651
Total: 113931888
Forums › The Car › 206 Problems › Misfire code p0200
Misfire code p0200
puzzledpigeon
PostPosted: Thu Aug 20, 2020 9:46 am Up
Hey all,
I have peugeot 206 1.4i 2002.
I'm currently having misfire and my neighbour kindly hooked up his diagnostics to it last night while I wait for my cable.
This was the result -
Is there some software though that can give a more specific p0200 code? Like what cylinder (1) for example. I'm going to use the scantools.net opensource software for ubuntu when the cable arrives.
However, I'd be grateful if someone can point me to some software that can monitor the injectors or do more to point me in to what to replace?
Thank you in advance for any assistance.
Merci! Wink
PostPosted: Thu Aug 20, 2020 2:37 pm Up
You haven't fitted NGK spark plugs to it I hope?
If you have then launch them towards the nearest bin & fit some Bosch ones - the 206 TU phase misfire detection system hates NGK spark plugs & its a well known issue.
Peugeot Planet 2000 is the most in depth diagnostic software for a 206 - but I doubt it would pin point which actual cylinder it is.
The coil pack is connected internally cylinders 1 & 3 as one pair then cylinders 2 & 4 as a second pair.
The 206 also runs a wasted spark ignition system so the spark plugs fire on both the compression stroke as well as the exhaust stroke - helps keep the spark plug tips clean.
There was also a modification done adding a condenser to the coil pack connector plug but that should have been done many years ago.
puzzledpigeon
PostPosted: Thu Aug 20, 2020 11:30 pm Up
I had my sparks changed by F1 Autocentre on June 29th. Don't know if they fitted NGKs.
Just ordered some Bosch ones from Eurocarparts though! Will see what happens come Saturday when I replace them. Thank you for that tip. Inexpensive, if it works great, if not it was only a few quid.
Thank you,
