Online Now [451]:
Visitors: 450
Today: 130347
Total: 156845234
Forums › Tuning, Modification & Legal › Project Cars › Project 309 GTi Goodwood
GazRG
PostPosted: Thu May 06, 2010 5:54 am Up
Looks very smart Bri, hope you're pleased with it!
'98 MGF 1.8i
Team: ex-206 owner
Brian
PostPosted: Thu May 06, 2010 10:13 am Up
Trade Rating: +31
Cheers Uz Very Happy Still a few bits to do on the outside like the rear chrome trim which i'm due a phone call for tomorrow. I started re-fitting the original stereo connector today which is fiddley but i think i've just about figured it out! Then i can get on with re-fitting the rest of the goodies! Smile Besides that i'm just after a cam belt change then after that i'll just be cleaning the car to bits up until FCS.
PostPosted: Thu May 06, 2010 12:15 pm Up
Looking very good Brian cant wait to have a closer look a FCS
PostPosted: Thu May 06, 2010 2:38 pm Up
Awesome! Cool
Dabamash
PostPosted: Thu May 06, 2010 3:07 pm Up
Staff - Daba
Wow, i'm amazed at the amount of work you've put in, looks mint!
I'll probably have a nose at FCS Wink
Dillon
PostPosted: Thu May 06, 2010 3:29 pm Up
Staff - Dillon
Cool
Brian
PostPosted: Thu May 06, 2010 4:59 pm Up
Trade Rating: +31
Bash on guys...that's what the car's going for...for people to have a nosey!
Cheers for the kind words Smile
I absolutely can't wait to get the audio gear installed and working Nom Nom Droolage!
Brian
PostPosted: Fri May 07, 2010 9:51 am Up
Trade Rating: +31
Well i THINK i have all the wiring sorted.
It switches on but i still need to get myself a code to actually get the thing to work.
I took a break half way through my stint to polish the centre of the steering wheel Smile
I've also started to route the cd changer controller up near the steering wheel which has involved removing the plastic bit that the ECU is connected to and removing the ecu screws to feed the cd changer controller through. I just need to screw it all back together, tidy the wires up and stick the side panel on and i should be nearly there...then onto drilling the holes for the CD changer and finding a way to plug up the old ones!
Kencoboy
PostPosted: Sat May 08, 2010 5:00 am Up
Hats off to you B tis car looks awesome have you got much left to do on her now?
Brian
PostPosted: Mon May 10, 2010 8:38 am Up
Trade Rating: +31
Cheers Smile Not loads left to do as such but just going to be a pain to round things up:
Finish installing head unit, cd changer controller etc and get a code for the head unit.
Install CD changer and plug off the old changer holes some how.
Chase up Peugeot for the 3rd time to get rear bumper moldings
Need to go back to Ecosse to get the black vinyls on the verticals of the doors which are NLA from peugeot so an aftermarket solution is required Sad
Might still get cam belt done and the cover put back on.
And then i'll be happy for this year.
EdCherry
PostPosted: Mon May 10, 2010 8:52 am Up
Do the belt yourself bri, easy peasy just be prepared to get some squashed hands!
Brian
PostPosted: Mon May 10, 2010 9:18 am Up
Trade Rating: +31
I dunno how confident I am at doing so though Ed and as you say, it is quite a squeeze, although probably a lot harder in a 205. I sort of want a receipt as well to add to the history of the car. I've been quoted around £150-ish to have it done including the water pump, so it's not too bad.
EdCherry
PostPosted: Mon May 10, 2010 9:21 am Up
Nah not bad at all really.
We did alot of maintence and service items one of the cars where the parts almost came to £150.
Brian
PostPosted: Mon May 10, 2010 11:14 am Up
Trade Rating: +31
Did a little bit more today. First thing was first...err put the car back together! Laughing
What i was doing here was removing the ECU holder and I unscrewed the ECU itself so i could get the cd changer controller through the gap as it's all wired up together, so i couldn't just pop the wire through and attach it afterwards which was a pain. Anyway it went through the hole fine.
I then tidied up all the wiring, put a velcro coin on the back of the changer controller and the other half on the dash so that i can hide it when need be on that little shelf under the steering wheel and attach it to the velco when i need it. I put the side panel back on and it's all turned out to look a bit like this.
Voila... now just to fit the CD changer, get a code for the stereo and hopefully it should all work!
Thumbs Up
Lecktorious
PostPosted: Mon May 10, 2010 11:16 am Up
Trade Rating: +59
There was a thread on stereo codes the other day and how to get the code, might be worth a search.
'98 Nile Blue 306 GTi 6
Page 6 of 10
