Latest: sparrowdclxvi
Overall: 17139
Online Now [85]:
Visitors: 83
Members: 1
Today: 8725
Total: 113310942
Forums › The Car › Solved 206 Problems › how to remove my spoiler
hectorbrocklebank
PostPosted: Wed May 12, 2010 4:42 pm Up
The spoiler on my 206 is the small GTi HDi one, however my old 206 has the larger GTi spoiler how do I remove both and what would people suggest to secure the larger one to my current 206. Ive Heard of people using strong liquid bonds alone. Is this a good option or is bolting it on going to be the way forward. Much apprectiate all advice please thanks.
M Carmichael
Lecktorious
PostPosted: Wed May 12, 2010 4:45 pm Up
Trade Rating: +59
All OEM spoilers are the same size, don't know how your GTi spoiler was any bigger Confused
'98 Nile Blue 306 GTi 6
hectorbrocklebank
PostPosted: Wed May 12, 2010 4:47 pm Up
well Ive just bought a HDi GTi and it only has a small spoiler on it although my old 206 has the spoiler Ive seen on the petrol 140 version
M Carmichael
PostPosted: Wed May 12, 2010 4:50 pm Up
Correct me if I'm wrong but if they are genuine pug and factory fitted then they will be bolted on and no glue used. Off the top off my head they are held on by 4 T15 Torc screws (or possibly T20). Just simply open the tailgate and locate them at the top under each end of the spoiler. Un screw and wobble a bit as it may not come off that easily if it's been on a long time.
To put a new one on most people use tiger seal as it does the job perfectly and bolting a new one on without precision is a pain + if you try and get it off will wreck the tailgate as it will have holes in it.. Having said that even using tiger seal you should apply without the intention that you will need to take it off in the near future as it's a right pain.
PostPosted: Wed May 12, 2010 4:57 pm Up
he might have the stupid WRC style one thats on some GT's
Lee.
PostPosted: Wed May 12, 2010 4:59 pm Up
Tigerseal the new one on, it will not come back off lol
PostPosted: Thu May 13, 2010 1:05 am Up
well the bolts if it's OEM fitting can't be seen when you open the tailgate,because they are hidden under 2 black plastic covers,you need to remove,and you will find the bolts under it,this is a few pics of it:
and when you hit these pins you saw in the pics,they will fill inside the tail gate,and to take them out,you need to take off the rear whiper motor cover,and use a hover to have them out from the corners.
then when you fit the new spoiler,use the bolts and tiger seal to prevent any future noise coming with bumpy roads :D,good luck.
hectorbrocklebank
PostPosted: Thu May 13, 2010 1:39 am Up
was it just a small screwdriver you used to get them plastic pins out mate?
M Carmichael
PostPosted: Thu May 13, 2010 1:42 am Up
not a small screwdriver,it was a nail,but i cut it's head so it don't damage the pins
hectorbrocklebank
PostPosted: Thu May 13, 2010 1:48 am Up
oh right yeah I see that now haha eyes are still trying to open up and so you just tap the centre of the pin inwards ant then remove the mushroom parts?
M Carmichael
PostPosted: Thu May 13, 2010 2:23 am Up
Exactlly Very Happy
hectorbrocklebank
PostPosted: Thu May 13, 2010 3:28 am Up
ok dude av got the wee plastic bits off but how do I now get to the bolts of the spoiler?If I cant see any bolts at this stage does that mean the spoiler is tiger sealed on?If so how do I know remove said spoiler? Very Happy
M Carmichael
PostPosted: Thu May 13, 2010 9:56 am Up
Fair enough I bought mine with the tailgate already taken off so that was probably already removed. Your saying you have taken off everything and you are left with bare metal but can't see any bolts?
hectorbrocklebank
PostPosted: Thu May 13, 2010 12:37 pm Up
no ive removed the covers that I imagine would cover the spoiler bolts and found no bolts the spoiler seems 2 be glued on
M Carmichael
PostPosted: Thu May 13, 2010 12:49 pm Up
Ah fair enough, I've never tried to get one off like that before. I would have thought melting it something, maybe a heat gun? even from the inside.. but can easily damage the paint. Sorry I couldn't help more.
