Latest: flipflap
Overall: 17140
Online Now [107]:
Visitors: 106
Today: 31438
Total: 113736451
Forums › The Car › Solved 206 Problems › Manifold rattle on GTi RESOLVED
Go to page Previous  1, 2
_mike_
PostPosted: Thu May 27, 2010 12:59 pm Up
I have just fixed an idential under load tap, it turned out to be the cat that had broken off inside - replacement - sounds spot on now!
I'm new Smile
2002 '51' 206 GTi in Moonstone blue!
nizuk1
PostPosted: Fri Jun 11, 2010 1:11 pm Up
Hi,
I think i have the same problem! I was told to try the knock sensor as it sounds like a pinking problem. Changed it, but no difference.
Is there any checks on the manifold i can carry out before taking it of?
Looks like a big job removing the manifold. Is it doable on the drive way?
Any ideas on the cost to get the garage to do it?
Cheers
EuroPeugeot
PostPosted: Wed Jun 16, 2010 10:43 am Up
nizuk1 wrote:
Hi,
Cheers
Im wondering on all this too..
PostPosted: Wed Jun 16, 2010 11:17 am Up
EuroPeugeot wrote:
nizuk1 wrote:
Hi,
Cheers
Are you sure that it isn't the clamp?
It is very simple, just uncomfortable.
Undo the old clamp from the manifold to the Cat and the U clip from the other end of the Cat to the manifold, remove Cat, look into the end of the manifold, mine did move about but it wasn't making noise, (the 4 tubes)
jayz206gti
PostPosted: Thu Mar 03, 2011 8:13 pm Up
Hmmm this seems strangely like the problem i just posted up about. Tapping under load but not when idling and oil level is fine.
Upgraded from 138 to 180
JonnyGTI
PostPosted: Tue Nov 22, 2011 7:21 am Up
This sounds like a problem I have just now on my gti but it also kinda sounds like the exhaust is blowing at the manifold or downpipe does/ should it sound like that
Cheers jonny
Page 2 of 2
