Posted: Mon Jun 07, 2010 3:05 pm |
Ah I see what that does now, I can imagine if it's really that strong though it will cause a slight increase in brake wear, as even that tiny fraction of pad/disc still touching will get scraped off as soon as you put the power on?
Posted: Mon Jun 07, 2010 3:21 pm |
The details are on the site.... As I understand it they can go anywhere between the M/C and caliper
Posted: Tue Jun 08, 2010 4:33 am |
In GTI180 you can only use 406v6 MC with ESP support.
| 2005 206 RC RED
Lot's of CNC machined customs pars. | |
Posted: Tue Jun 08, 2010 4:35 am |
@Schumi what about in a GTi without ESP (only ABS)?
Posted: Tue Jun 08, 2010 4:50 am |
Schumi wrote: |
In GTI180 you can only use 406v6 MC with ESP support. |
Are you sure?
Posted: Tue Jun 08, 2010 5:25 am |
180's don't have ESP do they?
Posted: Tue Jun 08, 2010 5:29 am |
Yep
Posted: Tue Jun 08, 2010 5:40 am |
Cool beanz
Posted: Tue Jun 08, 2010 8:55 am |
Mine has ESP, but I still cant imagine how V6's MC would fit into 180..
Posted: Tue Jun 08, 2010 11:55 am |
You can use every Peugeot MC's in 180. But if you want keep your ESP working you must use ESP capable MC.
| 2005 206 RC RED
Posted: Tue Jun 08, 2010 11:57 am |
=ZiAn= wrote: |
@Schumi what about in a GTi without ESP (only ABS)? |
You can use any bigger MC from another ABS model of Peugeot's. Like 306gti6 or ABS 406 3.0v6 coupe.
| 2005 206 RC RED
Posted: Tue Jun 08, 2010 12:21 pm |
Is the GTi6 master cylinder bigger than the GTi180?
Surely the 407 will have a big master cylinder in the range with ESP?
Posted: Tue Jun 08, 2010 12:23 pm |
It's exactly the same size Jamie...23mm.
Posted: Tue Jun 08, 2010 12:31 pm |
So 23mm is the biggest Peugeot do? What about the one in the 406 with ABS?
Posted: Tue Jun 08, 2010 12:33 pm |
Jamie wrote: |
So 23mm is the biggest Peugeot do? What about the one in the 406 with ABS? |
23mm but I'll double check when I go up to get some stuff from the 406 on Friday. I think some of the bigger saloon cars that peugeot have done iirc the 407 with the 4 pots has a bigger mc but not sure what size.
