Posted: Thu Jun 10, 2010 3:06 pm |
The part numbers above are the same though?
Posted: Thu Jun 10, 2010 3:07 pm |
What studs did you opt for Mac?
I got 1.25x12 48mm exposed length, with the matching open nuts.
Posted: Thu Jun 10, 2010 3:11 pm |
I have M12x1.50x80mm long here....... wrong!!!!
Posted: Thu Jun 10, 2010 3:43 pm |
From Rally Design?
Posted: Thu Jun 10, 2010 3:45 pm |
no... autoquip
Posted: Thu Jun 10, 2010 3:53 pm |
Ah right, how much were they?
Posted: Thu Jun 10, 2010 3:54 pm |
usually £8 for set of 8
Not including the nuts?
Posted: Thu Jun 10, 2010 3:56 pm |
no nuts
Posted: Thu Jun 10, 2010 3:57 pm |
Ok seems the same price as Rally Design, so if Autoquip can't get it right then give Rally Design a ring!
Part numbers SN23 & SN43 iirc.
Posted: Thu Jun 10, 2010 3:59 pm |
Cheers mate.... just got the top mount problem left to solve now
Posted: Thu Jun 10, 2010 4:00 pm |
I have no idea about that, have you contacted Gaz?
Posted: Thu Jun 10, 2010 4:04 pm |
Too late by the time I had thought about the possible issue.... will ring em in the morning now
Posted: Thu Jun 10, 2010 4:11 pm |
Hopefully mine arrive the right size tomorow, would quite like them to be in for FCS!
Remember to blue Loctite the studs into the hub!
Posted: Thu Jun 10, 2010 4:13 pm |
Just noticed your mate from Kam racing posted a Gaz group buy tonight.... I have asked about the top mount issue
