Latest: eltel666
Overall: 17146
Online Now [75]:
Visitors: 74
Today: 12331
Total: 116203921
Forums › The Car › 206 Talk › Where is my radiator drain plug??
Shaq22
PostPosted: Mon Jul 26, 2010 10:22 pm Up
Hello everyone!
I wanted to flush my cooling system and I am came into few problems. I was looking for the radiator's drain plug, and just couldn't find it.
By this manual, it shows me the plug is under the radiator to the right. But it seems I don't have this plug.
I was also trying to find it using Peugeot service site. here's a picture shows my radiator. Point C appears to be the drain plug, but in fact it's just another hose.
I really need your help!
Thank you.
sherman_2009
PostPosted: Tue Jul 27, 2010 12:21 am Up
What manual is that?
What type of 206 do you have?
Have a 206 LX 1.4
PostPosted: Tue Jul 27, 2010 1:30 am Up
Just pull off the bottom rad pipe and it will all come out, faster too, Wink
Geoff
PostPosted: Tue Jul 27, 2010 3:23 am Up
You might not have one... mine has snapped off sometime in its past.
As Ben says - take the bottom hose off.... just make sure the engine is cold!
apjs87
PostPosted: Tue Jul 27, 2010 3:57 am Up
yup, thats what i did. does the job nicely
No longer a 206 owner
Astra H sxi. 1.7Cdti
ExoVyper
PostPosted: Tue Jul 27, 2010 3:59 am Up
just be sure to get out the way fast when you remove it!
i made this mistake when doing a 7ton dumper radiator :S
dry much... not Razz
PostPosted: Tue Jul 27, 2010 4:55 am Up
as the guys said,just use the hose,faster and easier,and most 206 radiators don't have a drain plug,mine is 2006,and it don't got one,and i did the hose thing,and it worked great.
colin
PostPosted: Tue Jul 27, 2010 6:26 am Up
mmm good advice,also don't point gun at head and pull trigger. Wink
Shaq22
PostPosted: Tue Jul 27, 2010 10:26 am Up
I know I can use the bottom hose. I only afraid it won't come back into place.
My type is 206 1.6 i 16v (TU5JP4, NFU engine). The model called "One Line PK" (I guess it's made for Israel only)
PostPosted: Tue Jul 27, 2010 12:46 pm Up
Where in Israel are you?
PostPosted: Tue Jul 27, 2010 12:56 pm Up
It should go back Into place, won't change shape etc.
Shaq22
PostPosted: Tue Jul 27, 2010 6:02 pm Up
Ok. I hope no problems gonna show up.
I am from Petah-Tiqwa.
PostPosted: Thu Jul 29, 2010 9:15 am Up
you mean Beth-hatiqva??
Shaq22
PostPosted: Thu Jul 29, 2010 11:19 am Up
Just wanted to announce that I've successfully drained my radiator! Thank you all for your help. Very Happy
Sorry, but I don't know where Beth-Hatikva is..
Petah-Tiqwa is near Tel-Aviv, also near Kfar-Kasem
PostPosted: Fri Jul 30, 2010 8:14 am Up
Petah-Tiqwaa is near Tel-Aviv, also near Kfar-Kasem
Glad to hear that things went well :),and all worked out well for you,well I guess Beth-hativa and Petah-Tiqwaa is the same Smile
