Posted: Tue Aug 03, 2010 9:17 am |
Well went out to get in my car this morning and some1 has run a key (or something) down my drivers door. Nice big white scratch on my black 206. Any one got any tips on how i can try and reduce how horrible it looks.
Im soooooo angry!
Posted: Tue Aug 03, 2010 9:18 am |
how deep is it?
Posted: Tue Aug 03, 2010 9:20 am |
Scratch x or get it buffed.
Posted: Tue Aug 03, 2010 9:21 am |
| copey wrote: |
| how deep is it? |
ummm not sure how to explain i can like put my nail in it, some of the write bits came off and its like a silver scratch in some places. can def feel it tho.
If you can see the white primer through it the only way to get rid completly is a respray on those panels but depends how much you want to spend. if its thin and your tight, get a colour wax touchup lipstick thing then polish it, if you you want something mre perminant but equally as cheap, touch up paint and a really steady hand!
| This 206 IS going on a trackday despite it's every effort to stay at home in the garage! | |
as said, try some scratch remover or try getting the panel machine polished
Posted: Tue Aug 03, 2010 9:32 am |
| copey wrote: |
| as said, try some scratch remover or try getting the panel machine polished |
If the paints missing and down to the white primer there is no point getting scratch remover or having it polished! that will only remove more paint, it can't put paint back on can it.
Posted: Tue Aug 03, 2010 9:36 am |
| D4NTP wrote: |
| copey wrote: |
If the paints missing and down to the white primer there is no point getting scratch remover or having it polished! that will only remove more paint, it can't put paint back on can it. |
Calm down , we dont know how deep it actually is maybe it would be a good idea for th OP to show some piccys
Posted: Tue Aug 03, 2010 10:08 am |
scratch remover will do f**k all to a key scratch trust me, get a new door tbh
Posted: Tue Aug 03, 2010 10:10 am |
i would put up pics but left my camera at a friends house! ill give the car a good clean and t cut and c how it looks then!
thanks every1 4 advise!
cant believe sum ppl wil just key random cars 4 the fun of it
Posted: Tue Aug 03, 2010 10:11 am |
thats chavs for ya
Posted: Wed Aug 04, 2010 6:37 pm |
Had this done to mine a few weeks back its so annoying, at the moment its still there as scratch remover didnt make any difference, so its looking like an expensive respray job
Posted: Thu Aug 05, 2010 2:22 am |
they cheap way to do it is to get a touch up stick and some clear laqucer and some medium grade rubbing compound and the finest grade wet and dry sand paper you can find (2500+)
1.primer the scrath first let it dry
2. fill the scratch with the touch up stick (just slighty over fill it) let that dry over night.
3 soak your sand paper in warm water and washing up liquid lightly.
4. lightly rub the scratched area making sure it is always wet (do this until paint is smooth)
Repeat stages 1-4 until scratch is gone / barely visible
5.use some rubbing compound with a cloth not a machine just the help amooth it out a little more
6. give it a few coats of clear laqucer leave it to dry then use your rubbing compund on a machine polisher the remove any over spray from he door and apply polish to give it a good shine
I done this to my friend black honda civic EP3 (Night hawk black pearl colour ) he had two scratches one on his rear qaurter panel and one on his driver door about 3-4 inches long and then went right down to primer if i can find the pics of it before and after ill post them up
| 2003 Pug 206 2.0 GTI 180
IT TAKES TALENT TO BE THIS NOOB!!!! | |
