Online Now [847]:
Visitors: 846
Today: 54628
Total: 155354345
Forums › The Car › 206 Talk › 1.1 to 1.4 ?
1.1 to 1.4 ?
Forum Index › 206 Talk
Go to page Previous  1, 2
MEGA
PostPosted: Wed Aug 11, 2010 7:44 am Up
Rob2859 wrote:
Big_Rich180 wrote:
MEGA wrote:
The 1.1 or 1.4 -> 1.6 mod requires a few more things.
Exhaust Manifold from a 1.6 as the oil filter is in a different place
Injectors
Intake manifold as it is a different bore width
Custom induction or the induction from 1.6
The clutch is different.. You could use your 1.1 clutch, it is bolt pattern compatible - but it isn't designed for the abuse. I'd recommend getting a 1.6 clutch/flywheel
1.1 -> 1.4 is pretty simple however.
Wouldnt you get all that with a donor engine and box anyway?
most scrap yards sell the block on its own without the gearbox. if you could get a decent clutch for the 1.1 i would stick with the gearbox as the gear ratios are bound to be shorter.
Yes. I've used my old 1.1 gearbox as it is perfect for a track application. Maybe not quite wide enough to get me to max out the engine on a motorway but more than sufficient for the track.
Ideally I'd have a custom gearbox with even shorter gearing but a 6th gear.. But I suppose you can't have it all. Atleast not on a shoestring budget Smile :)
The Collection:
2009 E90 BMW 320d M-Sport: Remapped / ICE install / BBC CH Alloys etc
2004 Pug 206: The BEAST / Raaawr
PostPosted: Wed Aug 11, 2010 1:58 pm Up
Rob2859 wrote:
NorthantsBen wrote:
I could tell quite a bit of diffrence when driving my Mates OLDER 1.1 then getting In my 1.4,
Tho my 1.4 had trouble keeping up with jarreds (pugjh) NEWER 1.1 Laughing
think the older ones only have single point injection thats why. unless thats just on the saxo engines
Nar was multipoint.
curt
PostPosted: Thu Aug 12, 2010 6:01 am Up
I was just asking because the 1.1 I have in now is shot and I can't find out what is put(?) and I was just going to stick the 1.4 in because I can get hold of a cheap one off a friend not too bothered about speed or anything. I just want my car working again, thanks for the comments.
Please can you refrain from using text talk, thanks. Seb
1.1 bad boy :S
Rob2859
PostPosted: Thu Aug 12, 2010 6:44 am Up
curt wrote:
i woz just askin because the 1.1 i hav in now is F****d and i cant find out what is put and i woz just goin to stick the 1.4 in because i can i hold of a cheap off a friend not to assed about seed or ano thing like lol just want my car workin agen haha thanks for all the coments
thanks curt
in that case put a 1.4 in it. will cost no more as it is a straight swap pretty much.
MEGA
PostPosted: Thu Aug 12, 2010 7:17 am Up
I is jus finkin dat u should do dat den bro get a 1.4 and drop it in isn't it.
Evil or Very Mad
The Collection:
Page 2 of 2
