Posted: Fri Aug 13, 2010 11:44 am |
If I got an ecu from a same engine but from
A different car Ie 306 2.0l hdi would it be plug and play on my car ?
Posted: Fri Aug 13, 2010 12:00 pm |
No, it is linked to BSI and key transponder.
| Quiksilver: 1.6 16v Engine Conversion. | |
Posted: Fri Aug 13, 2010 12:59 pm |
Deffo NOT!
| +2 Positive Feedback
eBayer seller 206 GTI Spoilers, £120 Colour coded Inc Post!
ModifiedJunkies Performance Parts Centre
Proud owner of a french motor | |
Posted: Fri Aug 13, 2010 2:22 pm |
| vintageoriginal wrote: |
| No, it is linked to BSI and key transponder. |
Pre-multiplexed cars don't have a BSI.
Posted: Sat Aug 14, 2010 3:38 am |
Ahh ok no worries
Just as I need a backup ecu incase the 1 I'm
Mapping ever messes up .
Posted: Sat Aug 14, 2010 4:13 pm |
| Edward wrote: |
Pre-multiplexed cars don't have a BSI. |
They do actually. It's more simple than a multiplexed BSi but still present. It's located near the fusebox.
| '98 MGF 1.8i
Team: ex-206 owner
Team: Roof is always down when it's not raining! | |
