Forums › The Car › 206 Talk › 206 D-Turbo HDi - What to look out for? |
Posted: Wed Aug 18, 2010 11:57 am |
Hey, new to the forum.
I'm going to view a 2000 206 D-Turbo HDi. What should i look out for when i go see it?
Also, can these cars be remapped?
Thanks guys!
Posted: Wed Aug 18, 2010 12:39 pm |
have a look at the exhause before its started and give it a quick touch to make sure it hasnt been started before hand, as u wont see the big puff off black smoke on a warm start, when i say big, not the ushall deisel puff the one that coats the back off the car sort off puff.
also check around the fuel filler cap and indirect fuel pipe, see if it looks any newer than the car as with the age off the car sumone in its lifetime may have had petrol in it, could lead to other problems.
another quick check is to see the air filter and see how grimey it is, that should off been changed in its last service
Good luck with the veiwing, there beautifull cars to drive and alot off fun on sweeping roads, as long as there clear,
