Posted: Sat Aug 21, 2010 3:14 am |
i just wonderd whether this happens to anyone else. when i try to pull away quickly there is a slight delay b4 the power kicks in. like a flat spot.
Posted: Sat Aug 21, 2010 3:51 am |
That's where the missing 10-20 bhp should be, lol.
Posted: Sat Aug 21, 2010 3:57 am |
i have it on mine but then i notice it is the ESP kicking in and cuting power to stop the wheels spinning
if your is not swpinning then i would get a remap to sort the delay out
| 2003 Pug 206 2.0 GTI 180
IT TAKES TALENT TO BE THIS NOOB!!!! | |
Posted: Sat Aug 21, 2010 4:08 am |
i thought it was the lack of torque?
Posted: Sat Aug 21, 2010 4:25 am |
lack of torque would mean it pulls pathetically, not cause a delay.
I used to have the same problem but it reduced when I changed the crappy air filter for a K&N panel filter.
| 54' 206 GTi 180 Silver - K&N panel filter, Scorpion cat back exhaust, Parada Spec 2s | |
Posted: Sat Aug 21, 2010 6:28 am |
for some strange reason the gti180 between 3000rpm to 4000rpm all have a flat spot on them. if you have in on a dyno you will see it on a grath.
a remap can smooth it out but you can never really get rid of it.
| 206 Gti 180 Cat-camshafts 804's, Cat cams CTPE 002 exhaust vernier pully, RS tuning remap, Cat back janspeed exhaust, K@N Typhoon induction kit- heat wrapped, Exhaust manifold heat wrapped, Goodridge brake flexi's poly bushs in rear lateral arms, blue led speedo convertion, 50mm Eibach sport line springs, ......
180 Doctor
Hemwoods Gti180 / Pug specialist | |
Posted: Sat Aug 21, 2010 7:20 am |
really, i havent noticed that. just seems to be when i pull away
Posted: Sat Aug 21, 2010 7:29 am |
When was it last serviced?
Posted: Sat Aug 21, 2010 7:51 am |
yea i have it on mine dude....i am hoping the induction kit i am getting will sort it out but we will see
Posted: Sat Aug 21, 2010 4:47 pm |
june, it was serviced. every thing is new. even had cambelt change
