Latest: Willy.Sea
Overall: 17168
Online Now [112]:
Visitors: 111
Today: 11710
Total: 128514857
Forums › The Car › 206 Talk › Cold air feed
Cold air feed
Go to page Previous  1, 2
PostPosted: Sun Aug 22, 2010 4:20 pm Up
I had cold feed in bumper into standard airbox with k&n replacment pannel.
See pipe on this pic
Bleachtastesnice
PostPosted: Mon Aug 23, 2010 1:40 pm Up
Nice one ben, how did you rate it? Looks smart but was thinking of getting an sp grill and dont fany cutting into it
Cheers, Frenchie
PostPosted: Mon Aug 23, 2010 1:51 pm Up
seemed ok, not too much diffrence but was a 1,4 8v, lot smoother thorttle. and better than and induction kit as i seemed to get a lot of heat soak when had an induction kit.
had no problems with water etc too,
bertt
PostPosted: Mon Aug 23, 2010 2:01 pm Up
alright mate, im in the process of doing mine at the moment, both fogs however, what ive done is designed the piping with almost a sink like appearance with the swan neck in it, this meaning any debris which get in will be gatherd her, its a small section and is on butterfly clips so it can be removed and emptied if needed, tight meshing over the fogs also helps prevent this, the water also will gather in the u-bend and as i have puntured a hole in the bottom it will empty out through it on its own, the hole will reduce the pressure and efficiency slightly but i cant forsee any problems occuring with my design, i have even brought the piping together in a t-junction style fitting around the top of the rad to prevent any heat getting on it and plan to sleeve it in a protective material, other than a bad cough of all the fiberglassing it should be sound (:
jarvis483
PostPosted: Mon Aug 23, 2010 2:07 pm Up
to create something similar to that peugeot sport intake which t1mmy posted up, could you use a funnel like the ones used for petrol and similar? i think that could work?
>> IMAGINE IF BABIES WERE BORN WITH MUSTACHES
Page 2 of 2
