Online Now [653]:
Visitors: 652
Today: 101931
Total: 155196337
Forums › The Car › 206 Talk › Bleeding Circuit Advice needed
Forum Index › 206 Talk
206-GTi
PostPosted: Tue Aug 24, 2010 1:16 pm Up
Will be changing my passenger rear caliper shortly and was wondering the process of bleeding the circuits correctly.
I know the normal sequence is:
Passenger front left-hand wheel
Driver front right-hand wheel
Passenger left hand rear wheel
Driver right hand rear wheel
As I did it about 2 months ago.
Can I not just bleed the new caliper first and leave it at that?
Whats the best way to tackle this?
GTi - Black - 2002
richpowell91
PostPosted: Tue Aug 24, 2010 1:29 pm Up
I would say do it in reverse in order of the above to reduce the amount of air entering the system. I would also do all four corners at the same time. Also before you drive after make sure you pump the brake pedal to make sure there working.
PostPosted: Tue Aug 24, 2010 1:32 pm Up
How why/could you possibly do all four at the same time?!
richpowell91
PostPosted: Tue Aug 24, 2010 1:38 pm Up
Sorry meant same session as opposed to just doing the new caliper.
206-GTi
PostPosted: Tue Aug 24, 2010 2:11 pm Up
So Drivers rear, Passenger rear, Driver Front, Passenger Front?
I keep thinking it would make sense to bleed the new caliper first then bleed in sequence? The one line that will defo have air in is the new caliper line.
GTi - Black - 2002
sri16v
PostPosted: Tue Aug 24, 2010 2:29 pm Up
Always start furthest away from the master cylinder, so on a 206 go drivers side rear, then passenger rear then driver side front then passenger side.
2004 GTi 180
206-GTi
PostPosted: Tue Aug 24, 2010 2:32 pm Up
Thats what I have always thought but Pug say different (according to the service manual and haynes) and peps on here, tricky one!
GTi - Black - 2002
sri16v
PostPosted: Tue Aug 24, 2010 2:35 pm Up
I dont think either is wrong. Where I work we always bleed furthest away from the master. Try the peugeot way, must be a reason why they say to do it like that.
2004 GTi 180
206-GTi
PostPosted: Tue Aug 24, 2010 2:38 pm Up
Yeah strange!
Should I just connect the new rear caliper and start bleeding from the front paasenger wheel?
GTi - Black - 2002
