Posted: Tue Aug 24, 2010 12:47 pm |
Hi chaps,
i've left my owners manual in Carlisle, just raising the car to paint the callipers.
Whats the best point to raise the front of the car?
Cheers in advance
Posted: Tue Aug 24, 2010 12:48 pm |
sill or the subframe
Edit: my bad jacking point in the sill not just any old part lol
| Image removed due to size
Team, ST
Team, Gti 138 track slag | |
Posted: Tue Aug 24, 2010 12:52 pm |
Not the sill. It's only a narrow strip and do it enough and you'll crush it and definately split the underseal. Under the floor is a box section. Use this and a trolley jack with a thick block of timber between the jack head and box section.
Posted: Tue Aug 24, 2010 12:53 pm |
i used the bit were the wishbone it connected
Posted: Tue Aug 24, 2010 1:00 pm |
Regarding painting your calipers, What paint are you going to use? Been painting my rears in Hammerite smooth but it has taken so long to get a good finish, Was going to do the fronts whilse on the car but I will be there for days trying to get a strong finish.
Posted: Tue Aug 24, 2010 2:05 pm |
| 206-GTi wrote: |
| Regarding painting your calipers, What paint are you going to use? Been painting my rears in Hammerite smooth but it has taken so long to get a good finish, Was going to do the fronts whilse on the car but I will be there for days trying to get a strong finish. |
ooo... Well I did have Hammerite smooth. I'm back at my parents place at the moment and my dad wasn't too happy when he asked what I was doing and I told him I was going to be using his multi-grand bricked drive to do abit of spray painting... So the cars down now.. but at least I got most the muck off the Callipers
I did have Halfords brush on paint but exchanged it for a can as decided I wanted to go blue instead of red and they had no brush on blue paint. Did you use spray paint or brush on hammerite??
ooo and Edward, I ended up jacking the car up at the... erm... think it was the subframe? (damn my mechanical naivity ) Then put axle stands on either side of the frame and lowered the car so it was supported by three points. That sound about right??
Posted: Tue Aug 24, 2010 2:15 pm |
I got the brush on in red, has taken 4 coats to get a reasonable finish. Its reallly runny as well which doesn't help.
Posted: Tue Aug 24, 2010 2:18 pm |
| 206-GTi wrote: |
| I got the brush on in red, has taken 4 coats to get a reasonable finish. Its reallly runny as well which doesn't help. |
ooo... how long have you had the car up for to get that done? Guess you let it dry for 24 hours between coats so at least 4 days?
Posted: Tue Aug 24, 2010 4:13 pm |
Well, I have another set of calipers to hand so have been doing them in the shed, started yesterday evening with two light coats, about an hour between. This evening I did another two light coats and their just starting to look finished. Think another coat will be fine.
Dont even want to think about doing the fronts, as I will not have another set lying around prior, so will be on the car when I commence paint action.
Posted: Tue Aug 24, 2010 4:16 pm |
| 206-GTi wrote: |
Dont even want to think about doing the fronts, as I will not have another set lying around prior, so will be on the car when I commence paint action. |
bahaha! 'commence paint action'
hmm... well I'm doing mine blue. Hopefully over the space of around half a day I can get about 3 decent coats on. I thought 3 coats would be ample? Spose i'll just have to wait till I got a decent day..
