Latest: Andyblue64
Overall: 17123
Online Now [434]:
Visitors: 433
Today: 20551
Total: 98107798
Forums › The Car › 206 Talk › Gear box oil question
PostPosted: Thu Aug 26, 2010 5:47 pm Up
Is this stuff suitable for my gearbox?
www.eurocarparts.com/e...&cc5_310VP
Also, where can you get replacement gaskets for the plugs?
Thank you.
PostPosted: Fri Aug 27, 2010 12:25 am Up
Iirc that Should do the job, and you don't need a gasket on this type of plug that I can rember Of
PostPosted: Fri Aug 27, 2010 1:02 am Up
I recall 75/80 being the correct grade. I put a different grade on once and the gearchange felt awful.
