Online Now [43]:
Visitors: 42
Today: 85462
Total: 117442207
Forums › The Car › 206 Talk › Air horn help!
Air horn help!
Go to page Previous  1, 2
Rob2859
PostPosted: Fri Aug 27, 2010 5:28 am Up
I mean wire the horn in and burn the switch on the steering wheel. I will go have another look I couldn't see a fuse marked F5. they were just numbers, no letters
PostPosted: Fri Aug 27, 2010 5:36 am Up
Ah, OK.
What year is your 206?
Rob2859
PostPosted: Fri Aug 27, 2010 5:40 am Up
V9977 wrote:
Ah, OK.
53. I have a 15A fuse in the bottom right hand corner but its not F5
PostPosted: Fri Aug 27, 2010 5:51 am Up
Yours is plexed so have a look here:
www.206info.co.uk/Foru...t=108.html
It will be F13 (15A Blue).
Rob2859
PostPosted: Fri Aug 27, 2010 6:08 am Up
Cheers. will let you know how i get on
Rob2859
PostPosted: Wed Sep 01, 2010 8:37 am Up
Finally got some cable. wired it directly to the old horn and put a 30A fuse in. Thanks for the info guys. Saved myself a lot of time and wire Very Happy
PostPosted: Wed Sep 01, 2010 8:43 am Up
Excellent. Horns save lives btw.
I would go for 25A fuse (white or clear) when you have one.
This is specified as an option in the manual and you would
be doing things by the book then.
ExoVyper
PostPosted: Wed Sep 01, 2010 9:31 am Up
argh!!! you NEED a relay in the wire!
i learned the hard way on my old 106 when the stalk started smoking trying to melt :S
relays are really easy to put in when i get home and onto proper internet i'll draw a picture for you and post it up
ExoVyper
PostPosted: Wed Sep 01, 2010 9:32 am Up
also as an added bonus a horn plugging into a relay can use the full amperage of the battery so it's louder Wink
PostPosted: Wed Sep 01, 2010 11:28 am Up
No, the 206 already has a relay for the horn, confirmed. (see thread)
It would be pointless to add another relay in this case.
EDIT: I know this because I took your warning very seriously
when I was fitting mine and it turned out there already was one.
So cheers to ExoVyper for the heads up.
ExoVyper
PostPosted: Wed Sep 01, 2010 12:19 pm Up
ah right Razz
i always put one in which ever car i get after the close call in my old car lol
my apologies ^_^
Rob2859
PostPosted: Wed Sep 01, 2010 6:09 pm Up
much better than the old horn that was rubbish
Page 2 of 2
