Online Now [685]:
Visitors: 684
Today: 53947
Total: 128271593
Forums › The Car › 206 Talk › will brake servo affect handbrake?
PostPosted: Thu Sep 02, 2010 1:50 am Up
i always think on 206 the handbrake are mechanic tyre(by wire)
so even though your brake pipe burst you sthould still be able to pull the handbrake and stop the car?
or am i totally wrong?? Question
iainlovatt
PostPosted: Thu Sep 02, 2010 1:57 am Up
i would of thought the same! other wise the back wheels would stop suddenly all the time!
(My Garage)
ExoVyper
PostPosted: Thu Sep 02, 2010 3:09 am Up
yeah the 206 uses a cable to operate the handbrake Razz
spud_owen
PostPosted: Thu Sep 02, 2010 3:44 am Up
you are coorect, I thought every car has to have a mechanical handbrake? my 205 has a hydralic one but it is also attached via cables in case of a failure.
Honda Accord cdti....205GTI
LACEY AND OWEN ARCHITECTURAL SERVICES
www.laceyandowen.co.uk
PostPosted: Thu Sep 02, 2010 8:32 am Up
great, so basically my fd is wrong then?
at first when he pull the nadbrake one of the rear wheel won't lock up, and the garage fix it by change the servo lol
ExoVyper
PostPosted: Thu Sep 02, 2010 8:50 am Up
ah it won't have been the servo more than likely the slave cylinder cause if one of those has burst that side break is innefective
