Posted: Sun Sep 05, 2010 11:49 am |
Hi, I have recently brought a HDI with approx 90000 miles on the clock. There is no record in the service history of the cambelt being changed so I guess its high time it was!
My question is, do I just ask for the belt to be changed or is there other things that should be done at the same time, water pump etc?
How much should I be paying for this to be done? Dont want to get ripped off.
| 206 2.0 HDI Quiksilver & 206 1.4 HDI SW | |
Posted: Sun Sep 05, 2010 11:53 am |
Cambelt kit - includes tensioners, and water pump. Some garages will just do the belt, unless you specifically ask for the tensioners/pump. Wise to get all done at the same time, otherwise you may be back there is a few weeks paying again for a replacement pump! Not cheap but cheaper than a snapped belt.
Standard change I was told by my local dealer, is 80K or 10 years.
Posted: Mon Sep 06, 2010 5:02 am |
cambelt kits don't come with water pump make sure to have it replaced at same time.the kit will contain all tensioners and pulleys needed.cost will vary,but somewhere around £300 give or take.
