Latest: S2cgm
Overall: 17178
Online Now [418]:
Visitors: 417
Today: 38872
Total: 136060238
Forums › The Car › Solved 206 Problems › Door Card & Check Strap
Username
PostPosted: Wed Sep 08, 2010 7:58 am Up
I have finally bought my new check strap for the drivers door. Could some one though pls let me know where the screws are located to remove the door card to get at the check strap to remove it properly. Cheers all.
206 GTi With Full SP Pack.
C-MAN
PostPosted: Wed Sep 08, 2010 8:30 am Up
1 in the coin holder/handle. the others are located around the outside of the of the plactic on the door card
Now sold:Pug 206 1.4 Quiksilver 3dr
New car: Grande punto 1.9m-jet sporting
Team: the SillyHilly fan club
Was: monkeyboy69s Now: C-MAN
smiddies
PostPosted: Wed Sep 08, 2010 8:47 am Up
1 behind the tweeter cover iirc...
Username
PostPosted: Wed Sep 08, 2010 9:11 am Up
Thanks both, very much appreciated.
Ash
PostPosted: Wed Sep 08, 2010 9:27 am Up
One in the handle, One on the inside edge, one behind the tweeter cover (which pulls off).
You need to pull off Window Handles if you have them and you need to remove the cover around the door handle. Flat Head screwdriver will do the trick.
Then pop the door off... replace any clips you've broke (chances are, one or two will break... always happens)
Username
PostPosted: Wed Sep 08, 2010 2:48 pm Up
Check strap now changed. Cheers for all the info, very much appreciated Thumbs Up
