Posted: Fri Feb 19, 2010 6:14 am |
It depends, if you're handy with fibreglass it can be mounted anywhere. Some people have adapted it for the middle vents also, along with ashtray mounting etc.
I don't use the drivers vent that much to be honest, there's a window demister vent built into the top of the dash which does the trick.
| Daily Hack - 2013 Audi A3 Sport | |
Posted: Fri Feb 19, 2010 7:01 am |
i've got a similar thing for my iPhone...
an app called REV, and a OBDII WIFI reader. it does data logging, diag stuff and what not. is pretty cool
i love gadgets! lol
Posted: Fri Feb 19, 2010 8:49 am |
Is it accurate though? I've not find one that's as accurate as I'd like it to be
Posted: Fri Feb 19, 2010 9:31 am |
seems acurate... i've seen loads of reviews and no one's compained.
RPM's are bang on. MPH is just about bang on with GPS. etc...
it wasn't cheap like! reader was £140 and the app was about £23...
Posted: Fri Feb 19, 2010 1:52 pm |
Posted: Fri Feb 19, 2010 1:56 pm |
spike_202 wrote: |
My Powerflow is quite loud but then again it's on ITBs and has a decat. |
Audi Sport | |
Posted: Fri Feb 19, 2010 2:39 pm |
Quote:: |
Features
Main Menu
Gauge Display
Graph Display
G force
Speed timing
Faults and adaptations
Multigauge (Coolant, Air, N75, Boost)
Setup
Sub Menus
Gauge Display
Engine power
Torque
Boost pressure
Cmd pressure
Mass Air Flow
Air Fuel Ratio
Air intake temp
Exhaust temp
Coolant temp
N75 position
Oil temp
Graph data
Engine power
Torque
Boost pressure
Cmd pressure
Mass Air Flow
Air Fuel Ratio
Air intake temp
Exhaust temp
Coolant temp
N75 position
Missfire
Dyno plot
Timing Correction plot
G - Force Display
Bar Graph
Left
Right
Acceleration
Deceleration
Speed timing
0-60mph acceleration timing
0-100mph acceleration timing
Faults and Adaptations
Display and Erase Fault Codes
Big turbo setting for up to 500hp engines
English, French, Finnish and German language versions
Imperial or Metric units |
Posted: Fri Feb 19, 2010 3:25 pm |
nice one bud you'll need to let me know how you get on with it
| Evo 6 GSR & Track 172 cup | |
Posted: Fri Feb 19, 2010 3:36 pm |
Aye no worries. There'll be a few more goodies coming at the end of April I've got a couple of weeks off after next week, then I'm back to work, followed by my 'Ring trip, then as soon as I'm back I'll be getting the next phase done as well.
Posted: Sat Feb 20, 2010 3:14 am |
Howey wrote: |
That looks awesome! What functions does it have?? |
It provides geek and nerd data.
Posted: Sat Feb 20, 2010 5:13 am |
Edward wrote: |
Howey wrote: |
It provides geek and nerd data. |
You will be getting one next....
Posted: Sat Feb 20, 2010 5:45 am |
Geoff wrote: |
Edward wrote: |
Howey wrote: |
You will be getting one next.... |
Yep, he's right, it provides useless nerd info, such as when your oil temperature is sufficient so you can open it up without damaging anything, or you can find out the oil temperatures reached when used properly (on track etc). Boost Pressure readings so you can see if there are any leaks or problems. Fault codes that may crop up without illuminating the EML etc. Air/Fuel Ratio so you can monitor if its leaning out too much etc. Pretty Useless to be honest.
The full list is a couple of posts up....
Posted: Sun Feb 21, 2010 1:11 pm |
Posted: Tue Feb 23, 2010 2:25 pm |
Played with the Dumpvalve at the weekend, and mounted the new little camcorder! It boosts harder now, it is a bit louder but it's not too bad.
I got a delivery today My Race Diagnostics Liquid Gauge:
Comes with Password, Instructions / User guides, fitting advice. Brilliantly packaged and delivered in no time as well! Can't wait to fit it!
Oh yeah, also got a SEAT tax holder as well
Posted: Sat Feb 27, 2010 6:42 am |
