Posted: Mon Oct 04, 2010 11:58 am |
Don't now if this is in the right place but I wondered if anyone now where the ignition live relay
Posted: Mon Oct 04, 2010 11:59 am |
All relays are in the BSI
Posted: Mon Oct 04, 2010 2:31 pm |
Where and what is the BSI
Posted: Tue Oct 05, 2010 1:09 pm |
Found a box under the bonnet is that the BSI if so which one is the ignition live relay
Posted: Tue Oct 05, 2010 1:17 pm |
How old is your GTi? It might not have a BSI if it's a Y plate or older.
What's an ignition live relay? The main engine relay lives under the ECU.
The BSI is in the drivers fuse box, the very bottom, has about half a dozen fuses in it. Don't think about touching it unless you know what you are doing.
What do you need the ignition relay for?
Posted: Tue Oct 05, 2010 11:57 pm |
It's a W reg I've brought some daylight running light I was told to wire it to that
Posted: Wed Oct 06, 2010 5:04 am |
Edward wrote: |
What's an ignition live relay? The main engine relay lives under the ECU. |
All 206's have a BSI
crossie wrote: |
It's a W reg I've brought some daylight running light I was told to wire it to that |
Don't bother. Any ignition wire will do
Posted: Sun Oct 06, 2013 4:05 am |
I have been. Looking for everywhere to try to find a answer to this question...
Please
Can you post a pic of where to find a ignition +'ve wire under the hood
| Tiny, proud owner of a 2000 Peugoet 206 Style 1.1 (X reg) in Bottle Green | |
