Latest: SA01
Overall: 17138
Online Now [268]:
Visitors: 267
Today: 43536
Total: 112213366
Forums › The Car › 206 Talk › Gti 180 torsion bar upgrade worth it ?
b47t0n
PostPosted: Mon Sep 20, 2010 7:10 am Up
Is it reli worth upgrading my torsionbars to the gti 180 spec ?
Will I notice a posative difference ?
As I don't want to pay £60 per bar and £80 for fitting to be no different
So any body done this and recommend it ?
Got Smoke ?
Team:Apprentice Budget
Mrs_Howey
PostPosted: Mon Sep 20, 2010 8:31 am Up
i've done it Very Happy
Highly recommened it, just handles sooo nicely, and it doesn't twich either Razz
Moonstone blue 206 1.4look
pro race 1.2 White
Morettes
GTI wings
TEAM: Carbon Fibre Very Happy
Quarmbo
PostPosted: Mon Sep 20, 2010 8:43 am Up
Is this normal driving, or when your driving enthusiastecly or on a track? I would say to the OP, if your a steady driver then I wouldn't bother. If you like driving hard or track days, do it.
Ford SportGay-A
EuroPeugeot
PostPosted: Mon Sep 20, 2010 10:16 am Up
I've got one for sale Very Happy
PostPosted: Mon Sep 20, 2010 12:03 pm Up
Put it this way. Would you ever fit uprated springs on the front of any other car without uprating the rear? No? I didn't think so.
macj
PostPosted: Mon Sep 20, 2010 12:19 pm Up
OOPS....... I have Gaz custom coilovers on the front and standard GTi torsion bars with Gaz dampers on the rear... Handled Castle Combe rally day brilliantly and beat some big cars....
Lets put it this way.... If you can drive a car well, Have decent dampers, You dont need a stiff rear end, But as a rule... what you do to the front, also do to the rear.... Paul, I agree with you for road use
PostPosted: Mon Sep 20, 2010 1:30 pm Up
Standard torsion bars will enable the car to corner quickly and safely but if you also want to tune the suspension to enable the car to be a bit more tail happy and entertaining you need to stiffen the rear.
t.j.s
PostPosted: Thu Oct 07, 2010 1:00 pm Up
[quote="macj"]
Edward wrote:
But as a rule... what you do to the front, also do to the rear....e
I can just imagine someone saying it to their girlfriend Laughing
Are the gti torsion bars thicker or is it me thats thick lol Very Happy
Tom
no_offences
PostPosted: Thu Oct 07, 2010 1:15 pm Up
if you have decent suspension i.e a upgrade then dont bother unless your normal ones are on the way out
Signature removed due to size
