Online Now [865]:
Visitors: 865
Today: 215844
Total: 150516749
Forums › The Car › 206 Talk › Replace radiator?
Replace radiator?
Forum Index › 206 Talk
PostPosted: Mon Oct 11, 2010 11:07 am Up
Is it easy to replace the radiator? Or is this a garage job??
I think mines leaking water somewhere and need to replace asap!!
Teebag
PostPosted: Mon Oct 11, 2010 11:11 am Up
how bads the leak dj? pop round and can tell you what we could do..... have done rads before anyway so can help you do it.
my garage inc mod list:
- Antix
PostPosted: Mon Oct 11, 2010 11:13 am Up
I dont know mate, im not at home! But peugeot said a few months ago it was leaking then sealed itself up. So im presuming it might have came back?!!
Teebag
PostPosted: Mon Oct 11, 2010 11:17 am Up
put some rad weld in your coolant. should seal it all up again. if you want to change it can sort it for you. have got a spare rad of a gti in the back garden Smile
- Antix
PostPosted: Mon Oct 11, 2010 11:19 am Up
Rad weld?! Never heard of this before, will have a look. Ah sounds good, ill bare that in mind. Though a GTi one is different size?
Teebag
PostPosted: Mon Oct 11, 2010 11:21 am Up
can get rad weld from halfords. it seals small holes in the rad.
gti would cause engine to run a little cooler if anything lol, but as far as i'm aware the dimensions are the same.
- Antix
