Online Now [413]:
Visitors: 412
Today: 160412
Total: 155453404
Forums › The Car › 206 Talk › when changing brakes & Pads?
Forum Index › 206 Talk
Niallbg360
PostPosted: Sat Oct 16, 2010 5:45 am Up
Hi im going to change my brake and pads. In the haynes manual it says i need to replace the caliper guide pin bolts & new caliper mountin boltsJust wondered if this was necisarry as pug dealer has charge 40quid for new guide pin bolts.
Cheers
PostPosted: Sat Oct 16, 2010 5:46 am Up
nope.
unless they are really worn.
Nitrox121
PostPosted: Sat Oct 16, 2010 5:47 am Up
the guide pin bolts wont be £40..that be a guide pin set.
the bolts will be cheaper. dont know if you can get them seperate. usually you get replacement bolts with the pads (sometimes anyway)
Die Hard Member - Back For Round 2 -
New Car: BMW 318 Ti Compact M Sport
smiddies
PostPosted: Sat Oct 16, 2010 5:48 am Up
if i think the part your talking bout is the part im about to talk about...
then they should come with the brakes... and you dont need to go to main dealers for brakes.. as long as you can get bosch ones or something reputable will be ok!
Niallbg360
PostPosted: Sat Oct 16, 2010 5:52 am Up
well i got ftermarket pad n disks
colinmc
PostPosted: Sat Oct 16, 2010 6:45 am Up
use some threadlock on bolts.
mmm
Ally_Mufc
PostPosted: Sat Oct 16, 2010 7:57 am Up
i got new bolts with my discs and didnt even need to replace any Smile
17" Hijoin H286 Black, Red Rim Alloys
Custom Stainless Exhaust
